I have bought new smartfade 2496 device and dmx and 4 dimmer.... but i dont have digram how to connect smartfade with dmx and dimmer... please help me...
There isn't much to it with a few devices.
Each dimmer will have a "starting address" setting. Check the manual for how to change it. That dimmer will be controlled by its starting address and as many other addresses as it has dimmers. So if you have 3 dimmer packs with 6 dimmers each set then to #1, 7 & 13. The last dimmer in the last pack will be 18. And there you are, 18 dimmers controlled by channels 1-18
There is a lot to know about 'patching' and setting cues and all. So read the manual, watch the SmartFade videos and play around until you feel comfortable. And ask more questions here as needed.
Oh yes, this is the first of a nice series on the theory and practice of DMX512. https://youtu.be/z3jM_rbILhs
