Requests for New Fixtures in the SFML Library
Can you please add 8ch and 13c options for the Chauvet intimidator spot 255 irc?  I have attached two text files that came from Chauvet for the showxpress that should help in doing this.
ViewType = VIEW_TYPE_HEAD
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 540
ViewAngleTilt = 270
ViewAngleBeam = 17
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
2DViewImage = Chauvet/DJ/Intimidator Spot 255 IRC.png
Channel = pan
 Pan,0,255
Channel = tilt
 Tilt,0,255
Channel = color
 white,0,6 yellow,7,13 pink,14,20 green,21,27 red,28,34 light_blue,35,41 Kelly,42,48 orange,49,55 dark_blue,56,64 split_color,65,127 rainbow,128,255
Channel = gobo
 Chauvet/open,0,7 metal/Purplel dots Gobo,8,15 metal/Glass Gobo,16,23 metal/Fan Gobo,24,31 metal/bio,32,39 metal/Cloud Gobo,40,47 metal/Maze Gobo,48,55 metal/Atomic Gobo1,56,63 Miscellaneous/shake_gobo7,64,71 Miscellaneous/shake_gobo6,72,79 Miscellaneous/shake_gobo5,80,87 Miscellaneous/shake_gobo4,88,95 Miscellaneous/shake_gobo3,96,103 Miscellaneous/shake_gobo2,104,111 Miscellaneous/shake_gobo1,112,119 Chauvet/open,120,127 Miscellaneous/right_rotate,128,191 Miscellaneous/left_rotate,192,255
Channel = gobo_rotate
 stop,0,7 right_rotate,8,119 left_rotate,120,231 Gobo Bounce,232,255
Channel = prism
 open,0,15 prism,16,255
Channel = dimmer
 dimmer,0,255
Channel = shutter
 closed,0,3 open,4,7 strobe,8,215 open,216,255
ViewPower = VIEW_POWER_LED60W
ViewAnglePan = 540
ViewAngleTilt = 270
ViewAngleBeam = 17
Channel = pan
 Pan,0,255
Channel = upan
 16bit spinner,0,255
Channel = tilt
 Tilt,0,255
Channel = utilt
 16bit spinner,0,255
Channel = pantilt_speed
 Pan-Tilt speed ,0,253
Channel = color
Channel = gobo
Channel = prism
Channel = dimmer
 dimmer,0,255
Channel = shutter
Channel = control
 no_function,0,7 Blackout while pan/tilt moving,8,27 Blackout while moving gobo wheel,28,47 Disable blackout while pan/tilt/moving gobo wheel,48,67 Blackout while moving color wheel,68,87 Disable blackout while pan/tilt/moving color wheel,88,107 Disable blackout while moving gobo/color wheel,108,127 Disable blackout while pan/tilt/moving,128,147 reset_xy,148,167 reset_color,168,177 reset_gobo,178,187 reset_Prism,188,197 reset,198,207 no_function,208,255
Channel = movement_macro
 no_function,0,7 macro_1,8,23 macro_2,24,39 macro_3,40,55 macro_4,56,71 macro_5,72,87 macro_6,88,103 macro_7,104,119 macro_8,120,135 Sound Controlled program 1,136,151 Sound Controlled program 2,152,167 Sound Controlled program 3,168,183 Sound Controlled program 4,184,199 Sound Controlled program 5,200,215 Sound Controlled program 6,216,231 Sound Controlled program 7,232,247 Sound Controlled program 8,248,255
  • Hello -
    Unfortunately, it is not possible for us to make new fixture libraries for the SmartFade ML platform. It is possible for you to make the personalities you need using the console or SmartSoft software. Please have a look at the user manual on page 32 for instructions on how to create fixture personalities. If you get stuck, please feel free to contact technical support or post a question here on the forums.
    I'm sorry for the inconvenience - we are working on a better solution but are not yet at the beta stage for that solution.
    Thanks much -
    Sarah
