Memory sequence help
I've been told that it is possible to use memory sequences in the same way that you would use a stack.., For instance.. I want to record a sequence of Memory 1 and my next sequence I want to be Memory 3 but I want Memory 1 to wait until I tell it to go before It switches to memory 3.. Is that possible?? Just had the board a week.. tried to find on my own.
Shea
  • You can use the sequences on faders 21-24 in the way you describe. You'll need to change the run mode.
    Go into the LCD menu and navigate to Sequences. Hit enter. Then select the Sequence number 21-24. Enter. Then navigate to run mode. Enter. Then change the run mode to Manual. Enter. Home out of the menu.
    Now you will bring the fader up and then manually trigger each step with the bump button.
    Hope that helps.
    David
