party scene
i have tried and i have played with the stacks and sequences but i cannot make the smart fade 1248 do what i want. what i want it to do is basically after making the stack play its self over and over again any help
  • You need to adjust the Run Mode for your sequences to Loop. The Stack will not run in loop mode.
    Go to the LCD menu and navigate as follows:
    Menu:Sequences/Playback:[Select Seq 21-24]/Run Mode: Loop
