Can you link cues in the stack on a Smartfade 2496 to get a constant looping effect? I know you can jump to whichever step you like, and I know you can assign unique fade up, fade down, & wait times but I don't see anything in the instructions that would allow me to endlessly loop just a few steps of the stack & turn the stack into many little loops. It seems as if I may be able to do this using sequences. This is fine as long as the sequence can fade in & out of each step and not just bump from step to step like a traditional chase function (although it seems like it can do that too). Also, can you have multiple sequences running at one time? Thanks!
