I found the newest profile update and all my lights are listed. I cannot find in the manual how to get the new profiles into the console. Any help would be greatly appreciated. I have the ML, Thank you for your time
Hi there -
Check page 8 (v3.0.1 manual) for Load Personalities from Card.
So save to the card first. Didn't think of that. I'll get a card reader today
I have the latest software on both consoles and neither come up this way. Am I missing something? The card has the newest profile list but I can't bring up the Chauvet devices
I would like to clear all the devices in the console and replace with the new Persub.bin.
It doesn't work that way. You can't change the 500 that ETC has picked as "most common" you can only control the extra 100 with either ones you create yourself or ones you import from the library. You don't need to purge the 100 as you can overwrite any of the 100 slots that are available anytime. It is not an intuitive process and I don't know if using Smartsoft makes it any easier as I don't use Smartsoft much. Maybe someone with more experience will chime in...
RW...
I figured it out. It took a while. I finally just put the two profiles I needed in slot one and two and made them easier to find. It wasn't as easy as the manual makes it sound. Thanks for your time
