Inverting Tilt and using effects
Im running a show on a smartfade ml. I have eight MAC 2ks. Some of which the pan and tilt parameters are inverted. When I run the cosine linear effect on the pan parameter it doesnt invert the pan parameter. Is there any way to fix this?
For example I have 4 of them on an upstage truss and 2 of them are inverted to the other two. So when I pan one direction all four move onstage. Rather than all moving in one direction. That works fine when I use the encoders or faders, but what I apply the linear effects all four move in the same direction. Please Help.
Rob
