Hi all -
There is an updated fixture library available for download from the SmartFade ML Downloads page.
The following fixtures have been added:
Color Kinetics - iWBlast12Powercore
Color Kinetics - iW Blast 12 TR
Color Kinetics - iW Blast Powercore
Color Kinetics - iWCast14Powercore
Color Kinetics - iW Cove Powercore
Color Kinetics - iW Profile
Color Kinetics - iW Profile g2
High End Systems - XSpotCM/RG/IR Red
High End Systems - XSpotCM/RG/IR Std
Robe - ColorSpot1200EATM2
The following fixtures have been adjusted:
American DJ Rainbow PP II - Personality Changes:
Fade With Intensity for Slot 1 (Red/Cyan) turned OFF
Fade With Intensity for Slot 4 (Green/Magenta) turned OFF
Fade With Intensity for Slot 5 (Blue/Yellow) turned OFF
Chauvet ColorSplash 200B - Personality Changes:
Fade With Intensity for Slot 1 (Red/Cyan) turned ON
Fade With Intensity for Slot 4 (Green/Magenta) turned ON
Fade With Intensity for Slot 5 (Blue/Yellow) turned ON
DMX 6 moved from Slot 51 (Intensity fader) to 10 (Shutter/Strobe)
Chauvet ColorSplash Jr - Personality Changes:
DMX 1 moved from Slot 51 (Intensity fader) to 10 (Shutter/Strobe)
Chauvet MinSpot13channel - Personality Changes:
Chauvet Q-Wash LED - Personality Changes:
DMX 7 moved from Slot 46 (Macro) to 9 (Colour FX/Sat#2)
Clay Paky AlphaWash1200 16bV - Personality Changes:
DMX 13 moved from Slot 27 (User 3) to 29 (User 5)
Clay Paky AlphaWash1200 ExtV - Personality Changes:
DMX 15 moved from Slot 27 (User 3) to 29 (User 5)
Clay Paky AlphaWash1200 StdV - Personality Changes:
Coemar ProSpot 250 LX - Personality Changes:
Default Value for Slot 29 (User 5) DMX 16 changed from 0 to 20
Coemar ProSpot 575 LX - Personality Changes:
Coemar ProWash 250 LX - Personality Changes:
Default Value for Slot 29 (User 5) DMX 14 changed from 0 to 20
DTS XM1200Spot30Ch - Personality Changes:
DMX 20 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
Elation DesignSpot575E16bt - Personality Changes:
Default Value for Slot 21 (Zoom) DMX 15 changed from 0 to 255
Elation DesignWash250 16bt - Personality Changes:
DMX 1 moved from Slot 6 (Color wheel/Scroller/Hue#1) to 2 (Pan)
Default Value for Slot 2 (Pan) DMX 1 changed from 0 to 128
DMX 2 moved from Slot 58 (Cyan) to 49 (Pan fine)
DMX 3 moved from Slot 59 (Magenta) to 3 (Tilt)
Default Value for Slot 3 (Tilt) DMX 3 changed from 0 to 128
DMX 4 moved from Slot 60 (Yellow) to 50 (Tilt fine)
DMX 5 moved from Slot 2 (Pan) to 6 (Color wheel/Scroller/Hue#1)
Default Value for Slot 6 (Color wheel/Scroller/Hue#1) DMX 5 changed from 128 to 0
DMX 6 moved from Slot 49 (Pan fine) to 58 (Cyan)
DMX 7 moved from Slot 3 (Tilt) to 59 (Magenta)
Default Value for Slot 59 (Magenta) DMX 7 changed from 128 to 0
DMX 8 moved from Slot 50 (Tilt fine) to 60 (Yellow)
DMX 9 moved from Slot 54 (Focus time) to 33 (FX1)
DMX 10 moved from Slot 33 (FX1) to 21 (Zoom)
DMX 11 moved from Slot 21 (Zoom) to 10 (Shutter/Strobe)
Default Value for Slot 10 (Shutter/Strobe) DMX 11 changed from 0 to 255
DMX 12 moved from Slot 10 (Shutter/Strobe) to 51 (Intensity fader)
Default Value for Slot 51 (Intensity fader) DMX 12 changed from 32 to 0
DMX 13 moved from Slot 51 (Intensity fader) to 46 (Macro)
DMX 15 moved from Slot 46 (Macro) to 54 (Focus time)
NOTE: DMX Assignments Changed
"Lamp On" Device Command DMX channel moved from DMX 14 to 16
"Lamp Off" Device Command DMX channel moved from DMX 14 to 16
"Reset" Device Command DMX channel moved from DMX 14 to 16
Elation Design Wash 575E - Personality Changes:
Default Value for Slot 21 (Zoom) DMX 10 changed from 0 to 255
Elation Power Spot 575IE - Personality Changes:
1 Device Command Added
ETC Revolution - Personality Changes:
DMX 21 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
ETC Revolution RWM/RWM - Personality Changes:
ETC Revolution SWM/RWM - Personality Changes:
High End Systems StudioSpot575CMY Z - Personality Changes:
Default Value for Slot 21 (Zoom) DMX 17 changed from 0 to 255
High End Systems StudioSpot575Zoom - Personality Changes:
High End Systems XSpotCM/RG/IRStd - Personality Changes:
DMX 13 moved from Slot 46 (Macro) to 47 (Macro2)
DMX 35 moved from Slot 12 (BEAM 2) to 19 (Gobo 2 rotate)
Martin Mac2000Wash DW 16 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 2 changed from 255 to 0
Martin TW1 Extdim Ext. - Personality Changes:
Default Value for Slot 0 (Unused) DMX 5 changed from 255 to 0
Default Value for Slot 0 (Unused) DMX 13 changed from 255 to 0
Martin TW1 Intdim Ext - Personality Changes:
Robe ColorMix575ATM1 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 11 changed from 255 to 0
Robe ColorWash1200EATM4 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 27 changed from 255 to 0
Robe ColorWash2500EATM4 - Personality Changes:
Robe ColorWash575AT Zm1 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 16 changed from 255 to 0
Robe ColorWash575AT Zm3 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 18 changed from 255 to 0
Robe ColorWash575ATM1 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 19 changed from 255 to 0
Robe ColorWash575ATM3 - Personality Changes:
Default Value for Slot 0 (Unused) DMX 21 changed from 255 to 0
SGM GiottoProf.400 16 - Personality Changes:
Default Value for Slot 29 (User 5) DMX 18 changed from 0 to 127
Default Value for Slot 21 (Zoom) DMX 21 changed from 0 to 255
SGM GiottoSpot250 16 - Personality Changes:
Default Value for Slot 23 (Iris) DMX 5 changed from 0 to 255
Default Value for Slot 21 (Zoom) DMX 14 changed from 0 to 255
SGM GiottoSp400CMY16/8 - Personality Changes:
DMX 25 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
SGM GiottoSpot400 16 - Personality Changes:
SGM GiottoWash1200 16 - Personality Changes:
Default Value for Slot 21 (Zoom) DMX 11 changed from 0 to 255
Default Value for Slot 29 (User 5) DMX 13 changed from 0 to 127
SGM GiottoWash400 16 - Personality Changes:
SGM IdeaSpot575MkI14ch - Personality Changes:
Default Value for Slot 21 (Zoom) DMX 12 changed from 0 to 255
SGM IdeaSpot575MkI16ch - Personality Changes:
SGM SynthSpot700 16HRT - Personality Changes:
DMX 26 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
SGM SynthSpot700 16HRV - Personality Changes:
DMX 27 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
SGM SynthSpot700 16LRT - Personality Changes:
DMX 24 moved from Slot 12 (BEAM 2) to 20 (Gobo 2 mode)
SGM SynthSpot700 16LRV - Personality Changes:
Showco Wash 575 - Personality Changes:
DMX 12 moved from Slot 9 (Colour FX/Sat#2) to 7 (Color wheel2/Sat#1)
VariLite VL2500 Spot - Personality Changes:
VariLite VL3000 Spot - Personality Changes:
