Hello,
I need to crossfade two cues with a very short blackout between. I have found this note in the SF2496 manual.
DIPLESS: SmartFade provides dipless crossfades as long as both faders are moved in
parallel. This means that active channels which remain unchanged in both scenes will not
'dip' to 50% of their level as you move the crossfaders from one scene to the next, making
for much better-looking scene transitions. To create a blackout between two steps, move
only the Live fader to it’s end position.
So I expected that moving only the live fader up will create a blackout. Unfortunately the channels consisted in the next step remain on the minimal value from both crossfading scenes.
Is this behaviour correct? According to the manual this should happen only when the crossfaders are moved synchronously.
greetings, Jan
