creating a template for a fixture wiht multiple RGB channels
Is there a possibility to create a fixture wiht multiple RGB channels and just one intensity channel?
  • No, it is not. SmartFade ML has only one 'colour mix' controller per device, thus multiple sets of RGB can't be controlled.
    For this reason, such 'multi-cell' fixtures are specifically excluded from the personality database.
    The preferred solution is to patch each cell as a separate device, as you then have all the usual controls - including a 'virtual' Intensity for each individual cell.
    If this isn't possible, then you can build a User Personality to put the extra cells onto the other parameters that you find most suitable.
  • I was thinking just the same thing last night, thanks for clearing it up.
