That's right. We have the same problem. See "Device Commands does not work for Robe spots in SmartFade ML "
You can pass the bug with the following procedure:
- Set Parameter "User 5" at 52% for at least 3 seconds to strike the lamp (Lamp On)
- Set Parameter "User 5" at 92% for at least 3 seconds to turn off the lamp (Lamp Off)
Greetings Nico
Email: nivell@planet.nl
