Chauvet Legend 3000 - Lamp Off not working
With the SmartFade ML (with the latest library installed), it does not properly do a LAMP OFF command with the Chauvet Legend 3000.  Reset works, but Lamp Off does not.
Can this be fixed in the next library update?
Not sure if the Lamp On works or not (since I can't do a lamp off, and the lamps strike when the fixture is turned on).
Jon
  • Hi Jon,
    this is a bug.  We will fix it.  It affects any device where the reset channels and lamp command channels are different.  If reset, lamp-on and lamp-off are all on one channel then they all work.  If they are on separate channels then only reset works.
    Our apologies.  I hope we can fix this soon.
    adam
