problem with playback and sequence
I have a problem with SmartFade ml when I switch from one to another sena
parameters follow the trend of the motorized faders, but if I want to do
a rapid change in color should I press that button and very inconvenient to change fast, you can not do it with the slider
If you have a sequence with a long time as I switch from the first color
the last pass without following all the time but suddenly switch to the desired color.
excuse my English I hope you understand
