Problem with linear offset ...
Hi
I have a problem with offset for the linear effect. Everything is fine except for one thing. I don't know how to create the offset for intensity parameter, could you tell me?
For example, I select 4 MAC 250, choose "linear parameter 1" (let's say that it is an effect ON-OFF) for intensity channel. For this moment everytnhing works correctly but when I try to edit the Linear Offset by changing the Relation nothing happens.
I would appreciate your reply
Best regards
Kamil
