Hi! I have now had (really my school has had) a Smartfade 1248 for just over a year and I'm really enjoying it. While I know that the smartfade 1248 can't do Movers, can it control LED lights. My assumption is yes, but it isn't optimal since each LED unit would take up many channels and the smartfade really doesn't have enough ( I.E. the selador takes 8 channels, so you would take up every channel on the board by using 6 of them) or at least that is my assumption, correct me if I am wrong.
My second question is a little less relevant: I have access to some LED Pars and we'd be using them with the smartfade. I think I am able to get another controller specifically for them, but is it possible to use 5 pin DMX through my whole conventional system (3 dimmer packs) and then somehow convert 5-pin to 3-pin and use the 3-pin to control the LED units (they're not optimal, but you use what you have) and still have the whole system work?
Any advice is appreciated
Adam Joseph
