From YouTube user bubbihundur in regards to the video:
SFML 27 Introduction to Sequences
how can i switch from loop mode to manually or one shot mode?
ETCVideoLibrarian,
David Geel
ETCVideoLibrarian,
David Geel
David,
One page 73 of User Manual it describes how to change the "Run Mode". Link: SmartFadeML_v3.0_User_Manual_revA.pdf
Here's a snippet of the User Manual text from page 73.
There are three run modes for a Sequence: Manual, One Shot and Loop (default).
Step 1: Press EDIT
Step 2: Press TIME.
Step 3: Now press a bump button for a sequence. You will get this display.
Step 4: Use encoder wheel 3 to select [Run mode]. Press (MENU) to confirm.
Step 5: Select run mode using encoder wheel 3. Press (MENU) to confirm.
Step 6: Done. Press EDIT to exit.
At step 5 When you press (MENU) to confirm the run mode selected, you don't seem to get confirmation, it just sets it. I don't have a SmartFade ML but I have followed these steps with the SmartSoft ML software and it worked just fine.
Hope this helps.
DAN
