Execute a sequence in a stack?
I saw a post about a "sequence" that someone would like to have executed by a cue, but not sure if we're talking about the same thing..... I've created some sequences on the SFML that moves 2 lights from spot to spot to spot, and the sequences, and their timings, work fine, but I need these sequences to be executed when my conventional board (Express 48/96) triggers the cue.  I have MSC working fine - the Express triggers the cues in the stack just fine, but sequences don't execute.
Example: I have brought up Sequence 13, and have tried doing a 'Record All' into the stack as Cue 5.  When I execute Cue 5 from the Express, nothing happens on the SmartFade ML.  Should it?
Or, any other way I can execute a sequence from the Express's cues?
(function twremoval() { $(function () {$("div.twtr-doc").remove();}); })();
