Adjust intensity while in a memory
Ok, I was pretty sure I could do this before.... I have a memory recorded on the SmartFade ML, and I bring it up, and make a few adjustments, and either re-record the memory, or create a new memory with adjusted parameters (moving lights, not intensity-only fixtures).  Problem is, I can't change the intensity of the selected fixtures.  I can change any other parameter, but not the intensity.  I feel I used to be able to do this.... did I maybe hit a button on the board?  Or am I imagining I ever had that capability?
 - Jon
(function twremoval() { $(function () {$("div.twtr-doc").remove();}); })();
