Is it possible to disable the GM fader?
I have managed to break the fader and it's stuck in b/o so I was wondering if it's possible to disable it in the software as it wouldn't be a problem if it was permanently at 100%.
Unfortunately you can't disable the GM in SmartFade or SmartFade ML.
The SmartFade and SmartFade ML GM fader is ETC part number P153-F
You can get that from any ETC dealer and the majority are happy to fit it for you as well if you're not confident with a soldering iron.
If you're not sure then you can contact your local ETC technical service:
For technical support in the Americas, please call 608/831-4116, or toll-free in the U.S. at 800/688-4116.
For technical support in Europe, please call (+44) 20 8896 1000.
For technical support in Germany, please call (+49) 8024 4700-0
For technical support in Asia, please call (+852) 2799 1220.
