DMX out refresh rate
What is the actual refresh rate on the SmartFade 1248 DMX out. Even on the "Maximum" setting I am getting a deley to the dimmer. Just wondering how I can find out what the actual rate is.
TNX
  • The DMX timings used are listed in the Wiki here.
    For SmartFade, Slow is 20Hz and Maximum is 44Hz
    All the available DMX rates are much faster than any tungsten lamp could possibly respond, so if you're seeing a delay the DMX speed is not the cause.
    (Some LED, strobes and mechanicals can respond fast enough or use smoothing algorithms that show the difference.)
    My guess would be your dimmers have a "soft start" to protect the lamps (or internal electronics). This might be a timing setting you can adjust or 'lamp protect'/'soft start' setting you can turn off.
    Or it might just be that you're running lamps that physically cannot warm up that fast - 60W domestic lamps respond a lot faster than 5000W theatre lamps.
    (Edit - fixed link)
    [edited by: Richard at 3:34 AM (GMT -6) on Thu, May 24 2012]
