Default Palette Times
This isn't a question, more of a suggestion for a future software update.
Right now the default times for Focus, Color, and Beam are all ran off of the same speed.  The feature I would love to see in a future update is to allow the Focus, Color, and Beam to have separately controlled speeds.  Reason being is so that even if you want your LED's to change color at a 1 second fade, you might not want your movers to change position at a 1 second fade, since that is pretty fast.  Same thing with Beam where you might want your gobo's to change fast, you may want your movers to move really slow from position to position.
I guess it wouldn't be a big deal if you were recording everything you did and setting those times on an individual basis.  However as hands on as the board is, I tend to really only program effects and intensity masters and run everything else off of the Color/Focus/Beam palette.
