hi do,s anybody no were I can buy a new power supply for the express five pin
chz
ian
chz
ian
Ian,
I suspect that you should try the who are listed here:
https://www.etcconnect.com/Find-A-Dealer.aspx
Regards,
Martin T.
Ian,
Also, just in case you are not, be aware that there are at least two different types of low voltage connector. When I was in a similar position some years ago, despite describing exactly what I needed, the dealer sent the wrong unit and had to exchange it. In the mean time I had fixed the original unit with the aid of a screwdriver and soldering iron. Consequentially the venue had a usable spare.
Regards,
Martin T.
will check it out chz ian
