D40 yokes - BIG problem
I assume others are having this same problem. The yoke is so short the power and DMX cables won't pass thru, and if you want to hang them straight down you have to bend the cable at a severe angle that is going to destroy the connector very quickly.  The yoke needs to be at least an inch longer!!!!
