Has anyone had any look getting the knobs of AKAI APC 40 MK2 to work with Luminosus to control values such as pan and tilt?
Any help/advice would be much appreciated.
Many thanks :)
WOW! Looks like an old thread here - from what I can tell luminosus doesn't *natively* support something like that, however it is possible that you can create something like that if you can figure out how to translate the knob position into an osc command. I believe you might consult the EOS manual looking in the osc command /eos/key/encoder_X
