I have just started using Luminosus with a BCF2000. I really like it.
I have noticed a small problem when I have feedback turned on so that EOS send fader information back to the BCF2000. Whenever I move a physical fader it does a micro adjustment after the move. It is annying as this means after every fader adjustment the fader fires up producing a small sound and moving every so slightly. I have some investigation and it has to do with the fader value precision. Here is an example, lets say I move a fader and it sends the following OSC string to EOS:
/eos/user/1/fader/2/1=0.409449
EOS then sends back the following OSC string
/eos/fader/2/1, Double: 0.41
The problem is they are not the same value. Because of the small difference the phsical fader powers up and moves slightly. Does anyone have a solution to this? Maybe Luminosus should truncate or round the value to two decimal places?
