Pan/Tilt Values aren't accurate
If I select a group of fixtures to then move one at a time under the highlight feature the Pan and Tilt values stick to what the first channel of the group is not the channel I am working on.
  • Yes. Eos currently transmits the first channel in a group when you select the group even if you use next/last to step through the group and make changes. If you select the range of channels and use next/last you should have individual feedback for the different channels. This is an OSC transmit issue with Eos.
