I am very new to codeing and was wondering if there was a way to easily change what the encoders do. I would like to be able to make one do intensity and one color as I don’t need to use pan and tilt.
Samuel
Samuel
Here is the code for an extension which uses the encoder buttons as a home button,
for Teensy you should comment the same lines out.
For consoles you must do a trick with VID/PID, this is described on some other posts.
I hope that ETC will support Teensy Boards official in future, then I will change some of the basic light hack code.
I'll give this one a shot. Thanks again.
With teensy there is no limit with the number of parameters like on an UNO.
