Hello friend
there is a possibility to integrate light hack to receive contact closure and send OSC message to EOS? EOS (4) contact closure are too small for me... do you have suggest??
regards
Giovanni
Hello friend
regards
Giovanni
There are some manufacturers for Arduino based automation systems, which use optoisolated in- and output used for 24V systems. You can use it with USB or over ethernet. The code should be very simple to write but depends what you want to do (firing macros ...)
Controllino https://www.controllino.biz/#
Industrial Shields https://www.industrialshields.com
Rugged Circuits https://www.rugged-circuits.com
You might also look at the X-OSC for this - I've never tried it but I think you could make this work?
The price is yoke, £160 for what? You can do the same with an Arduino Nano 33 IoT for $16 and do it with your own software.
General OSC over WIFI is not always stable.
Thank you friend,
sorry for delay reply, busy and strange days in italy...
I will study your suggestions and let you know, thank you very much
best
Giovanni
MLJ
