The Bleed Build - Quick, Aggressive, and Deadly
One of the most effective PvP builds revolves around Bleed. Bleed is one of Elden Ring Items the most powerful status effects in Elden Ring, and it can quickly tear through your opponent’s health bar. A Bleed build focuses on fast, repeated attacks that build up the Hemorrhage status effect, causing massive damage once it triggers.
Key Components:
Weapons: The Rivers of Blood katana is a favorite for Bleed builds, thanks to its unique skill, Corpse Piler, which deals rapid fire Bleed damage. Alternatively, Uchigatana or Reduvia are also excellent choices for fast, precise Bleed buildup.
Stats: Focus heavily on Dexterity (for faster weapon scaling) and Arcane (for increasing the Bleed buildup effect). Endurance is also important for maintaining mobility while wielding heavier weapons.
Armor: Use light to medium armor for mobility, but prioritize items that boost Bleed resistance and reduce stamina consumption.
Tactics:
Aggressive Playstyle: The key to a Bleed build is keeping constant pressure on your opponent. Rapid slashes and pokes with a fast weapon can quickly build up the Bleed meter, forcing your opponent to react or risk taking massive damage.
Master the Corpse Piler: If using Rivers of Blood, use the Corpse Piler skill to deal continuous Bleed damage while creating distance between you and your opponent. The skill can also be used to catch opponents off-guard during their attack animations.
Dodge and Attack: Constant dodging and attacking ensures you don’t give your opponent any breathing room. Keep your distance, but elden ring items buy also know when to close the gap with quick combos.
