Active Channel Number
I've built a lighthack for my Nomad and it's working really well. It would be really useful to be able to display the active channel number too - does anyone know if this would be possible?
  • On a channel selection EOS send /eos/out/active/chan
    which contains a string with the channel selection and the value of the first selected channel. see manual 3.2.1 page 653
  • Hi sstaub
    Thank you, and I did that far on my own, but I don't know how to parse that specific value in the Arduino sketch? It would appear that the sketch only receives the /eos/out/ info after it has sent a query initiated by an encoder?
  • Which sketch did you use, the original or some sketch from my GitHub library https://github.com/sstaub/eOS
  • I'm using your sketch © 2019 with a version number of "lighthack box2B"
  • Maybe this works, attached a new file as an starting point. Have also a look to the comment
    - added a new String chanMessage
    - added a new filter rule to initEOS()
    - added a parser to parseOSCMessage()
    Things you have todo:
    - you must proceed the message to fit on a display
    - in displayStatus() you must handle the output to the LCD
    How do want display the data? With a larger LCD display(4x20)
    box2C.zip
  • Wow, thank you! Your commitment to the project is SO appreciated! :)
    I'll have a play with this tomorrow and let you know how I get on!
  • Well... that almost worked!
    If a channel is unpatched or is patched as a generic "Dimmer" or with a Type of "Fresnel" or "Profile" or "Parcan" then "/eos/out/active/chan" is the channel number and is displayed on the Lighthack display as a string of numerals. However, if the Type is anything more complex or the channel has a Label then two strange symbols are displayed on the Lighthack display even though "/eos/out/active/chan" is shown correctly in the Diagnostics Tab.
    I eventually tracked this behaviour down to the size of the chanMessageRaw array. The array is too small at 32 if the Type and Label combined are greater that 32 characters. Everything seemed to work correctly with the array at 96, so I erred on the side of caution and made it 128. I assigned chanMessageRaw to a new string variable, chanMessageFullString, and then set chanMessage as a 4 character substring 'cause Nomad will never use more than a 4 digit channel number.
    I hope this might be useful for someone else - but I could NEVER have got there without your initial work on this, so a big thank you!
    Here's my modified code:
    Global Variables
    String chanMessage; // for the channel message
    String chanMessageFullString;
    parseMsg = "/eos/out/active/chan";
    if (msg.indexOf(parseMsg) != -1) {
    char chanMessageRaw [128]; // size is max 32 chars
    oscmsg.getString(0, chanMessageRaw, 128); // size is max 32 chars
    chanMessageFullString = String();
    chanMessageFullString = chanMessageRaw;
    chanMessage = String();
    chanMessage = chanMessageFullString.substring(0,3);
    connectedToEos = true;
    updateDisplay = true;
    parseMsg = String();
    return;
  • As a hint the string send by eos is formatted in following way:
    <channel selection><space><[><value><]><space><type>
    To get only the selection, which can contain more than one channel, search for the first occurrence of the space char (' ') and take the string before.
  • That's a great idea—displaying the active channel number could definitely make troubleshooting and fine-tuning easier. Depending on how your lighthack is set up, you might be able to tap into the channel data if you're already intercepting or monitoring DMX signals. If you're using an Arduino or similar controller, you could write a simple function to parse and display the current channel. Curious to hear how you're pulling the data—might be able to suggest more specific tweaks!
  • Nia,  Is there a particular reason you are responding to multiple posts with what feels like responses built from an ai?  In the above response your listing of "intercepting or monitoring DMX signals" does not make sense. some of the posts you are adding responses to have already been answered and confirmed.
