Current unread threads
What "Unread questions and discussions" filter shows
Thanks for the report. After investigation, it appears that this issue only affects users who customized their home screen. Because many things changed in the upgrade, if other folks are seeing this issue, please revert your home screen customizations to default and then re-customize.
You're definitely not an idiot...
The process:
The issue described by sk8rs_dad was referring to the home screen and customizations performed there prior to the maintenance causing issues after that time. Are you seeing the issue on a page that is not your main home page? If so, can you send me a link? (PM if in a closed area)
Well, I assumed that this was related to the same issue.
My issue specifically: In forums, Eos Family for example, every new comment used to highlight that thread in blue. Now, all threads are black as if they have been Read. There are no "unread" messages.
I assumed his posts were being filtered out because they were marked as Read as well.
Note: Forums I do not frequent do not have this action. I just visited Response Networking Products and a comment from 13 hours ago is highlighted blue as new and unread.
Are you subscribed to emails from the Eos Family forum? If your email client allows the email to be marked as read, it also affects the notification of the thread being marked as read. The idea is that you've already read the contents of the post so why should you have to mark it as read in two places.
