How best to stop effects in time?
So I use EOS for live music busking. I have a showfile that references many cuelists to create looks on stage. All my cue lists are pretty granular so I can control each aspect of the lights on stage. I’m having a bit of a problem with exploring a new functionality.
what I’d like to do is be able to take the current state of my rig at any given moment and save it and then replay it. The idea would be let’s say there’s a song, and I get a really nice verse look going, I wanna save it and recall it later for the second verse.
So I figured out two ways to do this and both have their advantages and setbacks.
Method 1: playing a cue. So in this method I use a macro to say group 1000 (all above stage fixtures) make manual enter. Group 100 make absolute enter. (because I do have macros that rewrite pallettes) group 1000 record only cue 2/1. Enter. Group 1000 effect copy to cue 2/1. enter. (not sure how necessary this step was, but there were a few times the group order of effects did not properly copy over.) group 1000 make manual enter. Group 1000 make absolute. Enter. Sneak enter.
then to replay it you just hit go on the cue and when you’re done you can release the cue list. The advantage is if you make the cue 2/ a higher priority, you can actually use your usual busking magic sheet in an almost staging mode to set up the look you’ll eventually release the cue to. However you cannot make any changes to cue 2/1 without completely releasing it. The issue is when I release the fixtures, especially LED fixtures performing an intensity effect, they will take longer than expected to fully release and spend some time without any color data causing them to go “home” color for a moment, very unsightly.
method 2 fixes this issue but creates its own. I used the same macro to record but for play back I use a macros that says go to cue 2/1. Group 1000 make manual enter. Group 1000 make absolute enter. Release cuelist 2/. Group 1000 effect recall from 2/1. Enter. Now I still have total control of my magic sheet to make changes and edit live. And when I am done with certain aspects I can sneak the data out except I also have to stopeffect. the issue is that the effects need to be stopped manually since they aren’t sourced from a cuelist and all my effects reference cue/release time for the exit time, so they can only come to an abrupt stop.
Does anyone attempt similar behavior, and what work around with desk limitations have you found ?
