Yes, any logic cards from the Studio 575 series should work for each other, NOTE! The older Studio Color M and S boards will NOT work in a studio Spot of any type.
Don't forget to change the "Type" if you do change a board out in this manner.
Under the - Addr - Mode - Type (Color or Spot)....the fixture will automatically recognize what type of Spot (Standard, Standard Zoom, CMY, or CMY Zoom) it is, but if you are bringing a board over from a Color, you will need to change the setting.
