Trackspot DMX Problem
Hi Everyone. I am new to the forum. I just purchased some trackspots and one is not working properly. Hopefully you can help me. I have experience programming DMX lights and also experience working with electronics (lighting, amps, etc), so, I tried all the simple troubleshooting.
Anyways...the trackspot will not respond to DMX. I have the personality dip's on 3 and 5. I have tried several DMX channels and no luck. The unit powers up, it works in personality 1 (test mode). The light strikes, the gobos rotate and stop, mirror movement is fine, shutter is fine. It simply will not respond to DMX when I take it off of test and put it on the high resolution DMX settings, or the low setting for that matter.
I saw a post in here somewhere referring to the personality IC ( Integrated circuit). I am afraid this could be the problem. Is it? Any ideas?
The circuit board is a green board and the QC sticker says 11/5/96. I do not see the F2 ad F3 fuses anywhere on the circuit board like the HES manual suggests (the manual says F2 and F3 fuses would be the cause for no respose to data signal)
Please help. Thanks for your time!
Shane
Parents
  • [QUOTE=MusicProZ71;23784]I fixed my trackspot!!!
    Frank (puffyfish) was right - Hail the almighty Don at lightparts.com :notworthy: The guy is a genius and really explains everything so well.
    Thank all of you for all of your help. I will keep in touch on the forum. I am sure I will come across more trackspot problems because I have more coming in. :Eyecrazy:
    I know this was fixed long ago but I'm having the same problem right now, huge power spike hit the building, and lost 50% of trackspots (club i work in loves trackspots)
    How did you fix this MusicPro?
Reply
Children
No Data
