Currently to get to the Dots litho it scrolls through all of the gobo between open to the dots. Is there a way to set it to go the other direction since they are next to each other?
Nope....the gobo wheel inside the SHOWGUN is identical in physical function to the Cyberlight rotating wheel. 4 positions + open....just the SHOWGUN gobos are a lot bigger than the Cyber ones.
On both fixtures there is a physical stop in the wheel that prevents it from moving past that point.
So when you get to one side the only place for the wheel to move is back the other direction. This is also why you cannot do a continuous "gobo-roll" on these particular wheels.
The Litho Wheel in SHOWGUN does not have a hard stop. If you physically move it then it will continously rotate.
The question relates to a feature called Quick Path. This will take the shortest path to the next gobo (in your case not rolling all the way back through the gobo wheel but instead rolling from position 5 to position 1).
In version 1.4.0 this feature was removed from SHOWGUN due to some indexing inaccuracies.
I stand corrected....thanks for the clarification Zach. :beerchug:
