Trackspot Part and Problem
ok I have one Trackspot needs a new TS31F V4.1 chip as the one it was damaged when it was taken out then put back in backwards then powered up. The light worked fine before this happened, someone used the chip to try and troubleshoot another Trackspot, how can I get the replacement chip?
The second issue is I have a Trackspot that when it is powered up it seems like it has sezuires, i also makes a loud beeping kind of sound from the tilt motor. When the dip switch is swithed on to put it into self test mode there is no response, any ideas on what could be bad on the light? It looks like someone had taken or pryed the v 4.2 chip off before so I'm thinking that it is bad.
Parents
  • You can swap motor wires. There isnt any voodoo to it, no matter what motor wire you plug into what motor, all the logic will tell the motor to do is turn one way or another, whether it be a pan, tilt, gobo, shutter, color motor. In the moving heads though, you can swap pan and tilt motors but you cannot plug in a color motor to the pan motor for example (they normally do not let you do this anyways) due to the pan and tilt motors are usually 3 phase motors, and the color, gobo, etc are not.
Reply
Children
No Data
