I need some tips about replacing the logic card in a cyberlight CL. These lights have been in the air for quite a while and the logic cards are starting to go. What is the best way to remove the logic card? I have broken many a screwdriver trying to remove the DMX in and out ports on the card. Any tips? Thanks
Yup like Chris said. 4 holes 3 in a triange, the release is the fourth hole in the middle. Couple on the end going thru the bulkhead holding the card in place. Careful of the LED's!;)
man i didnt think the logic card was a common thing to go. I have burned though many more power cards than i have logic and usually the logic are repaired by a little chip swapping.
[quote=TimMiller]man i didnt think the logic card was a common thing to go. I have burned though many more power cards than i have logic and usually the logic are repaired by a little chip swapping.
True that! I'm thinking it's just a chip or two also.
