Lamp Power Supply Fuses.
How does one get at the lamp power supply fuses? I've taken apart the shogun as much as I'd like to, I can see the two fuses, but my hands aren't that tiny... Is there an easy access to this fuse? If the unit is on it's base, I've removed the two panels on top of the base, and the two side panels, the one that the dmx input is connected to, and the one that the addressing card is on, anything further seems like a lot of screws, and not a lot of access... Any ideas?
Brian
  • Hi Brian,
    I am assuming you are reffering to the two fuses on the left side of the lamp power supply, the side oppsite of the two fans on the LPS. The LPS is relatively easy to pull out. Once you have removed the side bezel (with the DMX plugs) There are two screws at the base of the LPS which are holding the LPS in place. Simply remove those screws and LPS will be free to slide out enough to access those fuses.
    Feel free to call me at HES 512.836.2242 ext. 1305.
    Hope this helps,
    Regards,
    paul
