Studiospot 250 pan error
I have a pan sense error on a 250 spot, the ld2 led is lit, is this a faulty pan sensor
  • [quote=chris_litz]Bob, Test the pan sensor in the menu:
    INFO, enter, SENS, enter, PAN, enter. It will read ON or OFF. Slowly move the pan by hand from one side to the other and see if the display changes from ON to OFF or vice versa. If it doesn't change then logic is not seeing the sensor so try changing the sensor.
    Chris
    The fault was in the loom to the motor, now repaired and working. What does the LD2 led indicate as I have a spare logic board showing this error
    Regards
    Bob
