Cyber SV Mirror Pan Brake Issue
Mirror Pan problems have aparently plagued HES for a while. First, the spring tensioner mechanism thingy; which worked until you turned the fixture 'right-side-up'. Then they moved to the motor shaft damper/brake arrangement; that works better, but . . . Now there is apparently is a little known upgrade for the mirror "braking" system to include two (2) brakes on the mirror Pan motor. This is available as the "Motor Brake Upgrade Kit ($40 . . . something).
Look, I happen to have over thirty Cyberlight SVs in the show, and nine spares. All of them have the "pre-upgrade" single brake version. Unless anyone has a better option, I plan to add a $9.00+ brake, and modify the existing motor shaft (Machine the shaft end by 3/16" so the set screws meet the motor shaft).
Does anyone have any other Cyber SV tips? Help.
TNX,
Rick51 :confused:
Parents Reply Children
No Data
