USB Widget Driver
Greetings,
Is it possible to download the actual driver for the USB widget ?
I'm attempting to use the ECHO software in a completely unsupported way and I'm curious to see if I can actually get some results...
I'm running a MacBook under 10.5.7 and since there is no Mac Version of the software obviously, I've preformed a bit of an experiment...
using "Crossover" www.codeweavers.com/products/cxmac/
I've been able to successfully install and launch the ECHO application...
amazingly it seems to run just fine... EXCEPT it wont see, and install the driver for the USB widget...
is there an installer for the USB layer driver for windows or for the widget specifically that I can grab and attempt to install?
I'll be happy to post my results for other end users either way.
- yes i know i could run Parallels or VMware or Boot Camp but crossover seems to run this app just fine without Windows installed -
thanks in advance,
Michael
