I opened up one of my Cyber Turbo's to calibrate a color flag or two. I had the module laying over the lamp area (lamp off) and turned it on. It went through it's setup, then everything started going crazy... flags moving in and out, iris, focus, pan/tilt just keep moving. I've calibrated before with no problems, and just calibrated another one last Friday with no issues. If I put it into self-test it does fine; put it back into normal mode and it starts going crazy again. Is this a control connection issue on the fixture? I just used it Sunday and it worked fine (except for a flag not opening all the way- hence the need to either calibrate or change motors :mad:. Ideas?
May have been a loose XLR connector, as in not having the locking pin secured like it should. I think I've read about that before on this forum. I don't know, but it seems to be working alright now...
