Technobeam Pan / Tilt Accuracy Issues
I know this is now a Strong product, but I am hoping some HES users or staff may still have some help with this.
We have several Technobeams in a rig exhibiting some positional accuracy issues. Others are fine. Most of the problem units seem to have problems with the Pan accuracy.
Once they are powered up or homed, they do not home to the same spot each time. If you grab them and manually move them to their limits you'll see them step back a "cog" or "notch." Some of them will be fine after that. You just have to run them to their limits before using them.
Other fixtures seem to home a step or two off and even after running them to their limits it seems that they home to different spots about 50% of the time. We have done hub set-ups on them and the motors don't feel steppy. Basically have to keep rehoming them until they hit their mark or you end up editing their position every day.
Wondering if anyone has some suggestions to improve their accuracy. Thanks.
Travis Slyter
