Studio Spot/ Studio Color
I have a studio spot 575 CMY zoom that recently developed a problem with the lamp power supply, the lamp will not stay struck. I called High End and the tech helped me to isolate the problem to the lamp power supply board. I happened to have studio color 575 laying around that was having the same symptoms. When I opened up the studio color, I found that one of the components had come unsoldered. I soldered it back together and then put in the fixtures. It solved the problem in both fixtures. Fast forward a day, I am using the studio spot in a show right now and the lamp goes out again. I pull down the fixture, and find that the same part is unsoldered from the board again. I repeated the process with the same result, the part keeps coming off the board.
I tried locating an ID for the component, but I couldn't find anything. Its a circle with wiring wrapped around it. When the board is installed, and the fixture is head down, it is towards the top of the board. a) What is it? b) what would cause it to keep heating up enough to melt the solder? c) is it actually melting the solder or is it just the weight of it breaking free from the board?
please help!
  • Small ring with wire wrapped around it, and a lead going through it perhaps? If so, it may well be one of the current sensors used to see if the lamp is lit. Lose that, and te fixture will never know the lamp struck.
    What are you soldering it back on with? I can't imagine anything that would get hot enough to melt most electronic solder without causing extensive damage otherwise . . .
    - Tim
  • No... its one of the transformers on the board. Since posting this, we have discovered that the theatre got hit with a large power surge over the weekend, and that seems to have blown out components in a couple of my moving lights... now I'm scrambling to find something to substitute for a show that opens this weekend...
  • Ouch! Do you just douse your lamps but leave the units on?
  • Prior to this event, yes, that was the standard protocol. Now, they the power to every fixture every night when they are not in use. We lost a total of 4 fixtures from this incident. 2 need a new/repaired lamp power supply board (these will hopefully be sent in for diagnostic/repair in the next few weeks). 1 needed a new filter board (I ended up driving to Upstaging in IL to get it repaired during tech week). The final one is a completely dead fixture currently. The surge literally fried the logic board. There is a giant burn trail of black and melted circuit board on it. Its kind of surreal to look at it and see the damage. I don't know what they are going to decide to do with that one.
    At any rate, now main power is shut off every night.... it was an expensive lesson to learn though.
