[QUOTE=jeremyandrews03;46303]I've got an error that says "err rote tab not found" i'm assuming this is a gobo wheel, which one?
I am going to take a stab that it is the tab on the rotate on the effects wheel - the one with the prisms and such . . .
In any case, if you watch it home with the covers off, it's typically quite apparent which one is missing, since they spin far longer than the others . . .
