I've got a StudioSpot 250 with some cracks in it's plastic casing (front nose section), can anyone recomend a glue that will bond the plastic back together properly to effect a repair?
depends on the type of damage. crazy glue type stuff seems to work fine for thin small cracks. plasic epoxy for heavy cracks and broken parts. And for missing chunks (well small ones anyway about the size of a dime) try some weld stick epoxy(it's a 2 part puddy epoxy, dark grey color) tip with the weld stick build it up thick, it can be sanded, drilled, even ground down (drimel works great) and you can dust it with a little black spary paint.
Yeah, two part epoxy is probably the way to go. But the best would be if you could get a new front cover.. Check the HES Parts list on: www.highend.com/pub/support/parts/PartsPricing.pdf
