studio spot 575 reset and home Problem
I have one of my 575s that is acting up and need some help. this unit will run good for a bit then will lose its lamp and reset and home then will not relight. i must go thought the menu or just power down. also at the same time i will lose all of the Led diplay lights they flash off and on a couple time then the unit will start to reset somtimes it get through a complete home cycle. Ok here what i have done so far i have had the software crossload replaced the dmx chip i swaped out the logic boards and also the lamp power supply board and it is still acking up Not sure were to go from here
Thanks Doug
