built 3-24-99... Lamp blew and put new lamp in, nothing happened,, took off cover and F3 was blown, so replaced the fuse and it continues to blow it.. Any Suggestions appreciated.. Paul
The ballast may be bad. Unplug it or swap from another unit and see if the fuse blows. Running lamps past their rated hours in any unit puts added stress on the components and risks in lamp rupture. Does the fixture stay on after the fuse blows? Also what version logic boArd do you have?
