Ligting
I am expanding my business and currently typically use a chavet 4 bar with a chauvet 4 play for most venues. I will be running two rigs therefore need lights for second show. I was thinking the 4 bar tri.
However my last show I was at which was a farm in a long tin shed and I had at least 50 feet from the door and people said the 4 bars were pretty bright, which turned out to be my fault on the angling of the lights.
In the end do I spend the money a brighter 4 bar tri or just get another matching 4 bar? Benefit of the 2nd 4 bar would be master slave via dmx option (I do not use a controller, just sound active) and also for larger shows to have one on each side as well.
Thoughts?
_____________________________
fluorescent led bulbs
led ceiling lights
led strip lighting
