I'm getting an Over Temp on one of my units as soon as it boots up and completes the homing process. Fans are working, in fact it is running at high speed. I've re-seated all of the sensor connectors on the logic board, but noticed those are all for systems control like gobos, pan, tilt, etc. Where are the Temp Sensors located so I can check those specifically? Thanks!
The temp sensor is actually on the logic board located at U2. I would swap the logic board between the faulty fixture and a good fixture to be 100% sure that the issue is withing the logic board. If it is determined that the logic board is indeed the problem then contact Light Parts to have it repaired.
